![]() | Home > Technical (L322) > FSR wiring ? |
| bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140
Hi, did you ever solve this ?
I’be just replacement connector with one off eBay that is sold for BMW”s, cut off the old and soldered in the new. In doing so, I extended the loom by approx 15cm, so made it much easier to refit the FSR connector as it was less tight to navigate the hand under the steering column / centre console.
