Home > Technical (L322) > L322 2012 Clunking sound
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
I think mine needs doing as well, getting rumble from centre of the car when under constant load or under acceleration.
Where did you source the bearing from? And how much was it?
Post #566168 3rd Sep 2020 10:44am
Mousey
United Kingdom 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
I got mine from Propshaft Technix on eBay, £35 del.
Post #566170 3rd Sep 2020 11:27am
lighthouse
There seems to be some confusion some quote 02 - 09 and some 02 - 12 mines an 11, but guessing they are all the same anyone know?
Post #566173 3rd Sep 2020 12:36pm
Sandyt
When I did mine I had the prop refurbed with new ends made a real difference
Post #566214 3rd Sep 2020 6:32pm
lighthouse
LR Parts sell the entire shaft including the bearing for 271 plus vat, wondering if its worth / easier to swap the whole thing, they also sell the bearing for 22 +vat.
How easy was it to swap the bearing out and separate the propshaft.
Post #566220 3rd Sep 2020 7:19pm
Mousey
Mine was an absolute b**tard to split, took longer to split than to get the entire shaft off of the motor !! Had to use more heat than I would have liked so am now hoping that hasn't affected the center u/j.
With hindsight I would have swapped the entire shaft.
Post #566253 4th Sep 2020 10:08am
lighthouse
I think I will just buy the whole shaft then, that will make it quite a simple job.
Post #566254 4th Sep 2020 10:22am
Mousey
Hardest bit will be taking exhaust off or trying to get the heat shields out without destroying them.
Post #566261 4th Sep 2020 10:54am
D3Jon
I don't know the definitive answer as to whether rear prop centre bearings can be replaced seperately on post 2007 cars - But I'd like to know myself now!
I just happened to be on Advanced Factors website buying a few bits for my early L322 and they list a separate centre bearing upto 6Axxxxxx and from 7A (2007) onwards all they offer is a complete prop? As below:
Does anyone know why that is, does it mean that the 2007 onwards prop can't / shouldn't be split?
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #566271 4th Sep 2020 12:26pm
Mousey
Mine is 2012 and I managed to obtain and fit the center bearing! only issue was rust in the center spline which made splitting difficult.
Post #566355 5th Sep 2020 8:50am
D3Jon
That's good info, thanks! Thumbs Up 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #566360 5th Sep 2020 9:41am
