Home > In Car Electronics (L322) > camera modes
phil666
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
camera modes
hi all ive just replaced the camera on my 2006 vogue but the wide angle view in the camera check menu looks better than the normal view is there anyway of having the wide angle view as standard
Post #565195 22nd Aug 2020 5:57pm
Nick591
I too wondered why the view normally shown when reversing is considerably cropped when compared with the view via the camera check screen.
Does anyone know if it is possible to alter the view shown when reversing to the full uncropped view from the camera?
Fyi I changed my camera to an aftermarket one when the original stopped working but that doesn't alter the basic question as the video feed to the head unit clearly is wide angle. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #565570 26th Aug 2020 3:26pm
Ianb4310
I’d like to do this as my camera shows a black screen when reverse is selected do you have a link to the camera you bought please
Post #566600 8th Sep 2020 11:37am
Nick591
Camera
Hi Ian,
Sorry for the delay. I used this from ebay
https://www.ebay.co.uk/itm/332626937827
you will need to modify the standard camera housing so this camera can fit and then play around with the angle of the camera before I then used black silicone to seal it and hold it in position. I also used the connectors off the old (standard OEM) camera and joined them on to the new camera wires so that the loom on the car remains standard.
It is a bit of a faff to do but quite satisfying and much less costly than an OEM camera.
This replacement camera has the reversing guidelines which aren't that useful IMO but the picture resolution is better than the OEM, especially in low light conditions with the dreadful RR reversing lights even after fitting brighter LED bulbs!
Good luck!
Cheers, Nick Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #566900 12th Sep 2020 9:27am
