![]() | Home > Technical (L322) > Air conditioning fan not working |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
Hi,all hope you are safe and well ,my electric fan for the air conditioning is not coming on is there a fuse or relay I could check I cannot seem to find any information on it the fan spins freely and is smooth when spun by hand,help much appreciated |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
Try Fuse 12 10A and Fuse 34 7.5A on the front fuseboard for starters. |
Tried the fuses both ok mine is a td6 not sure what to check now |
clemenz Member Since: 13 Sep 2014 Location: Graz Posts: 183 ![]() ![]() ![]() |
Same here! Do you have any tester? |
I have just scanned it and it is coming up with 0480 fault code |
Does anybody know the location of the temperature senser |
The ac ambient temperature sensor is clipped to the rear of the front grille, lhs. |
I have the same problem, A/C fan not starting when i turn on the A/C.
