Home > Technical (L322) > Tdv8 whistling turbos
Oddvar.L
Norway
Hello from Norway🙂.
New member/owner of L322.
Just bought me a 2007 tdv8.
Only driven it 3000km yet, but what a car.
Like a magic carpet, realy flying.
A little conserned about whistling sounds from engine compartments when i give it a little stick. Thats as giving it alittle more stick than my wife would have done🙂.
Since I'm new to this car, I dont know if this is normal, or should I be nervous, planning for turbo havoc etc.
Would like to hear from expirient owners.
Excuse my bad English, but probably better than Your Norwegian🙂
Post #565514 26th Aug 2020 7:18am
Bluegreygreen Rangie 2
Australia
Without hearing i really dont know but make sure you do not have a boost leak from a split intercooler hose etc... If you do generaly youll get black smoke and reduced performance if it is bad enough ... your turbo can also overspeed and fail which is why i say check it out
The are lots of threads and info on the top intercooler hoses failing (not saying thatis what it will be / your noise is)
Dave 2010 3.6TDV8 Autobiography
D4 Bullbar, Bas remap, Egr deleted (blanked & via remap) , Cold air intake, Turbo back exhaust, Provent 200 catch can, Banks idash gauge, 255/60/R20
GAP Diagnostics
Past - 02 & 03 TD6 And an 1984 Classic
Post #565577 26th Aug 2020 4:28pm
Oddvar.L
Norway
Thank You for Your response.
I will investigate furter, now that I know this is not normal. I have not notised any black smoke, and not sure of laking performance.
Never driven any others tdv8's.
10 years of Discovery td5 driving makes this thing feel like a formula1 car🙂
Post #565602 26th Aug 2020 8:59pm
Australia
To be honest with you I've never been in another TDV8 either which I'd like to do.
I also had a TD5 for a while some years ago... Yes slight difference Laughing
What you describe doesn't sound right... Maybe do a voice clip or quick vid for YouTube.
GAP Diagnostics
Post #565617 27th Aug 2020 5:15am
mpirie
Are you sure it's the turbos?
You can sometime hear a whistle coming from the windscreen surrounds when the speed and wind direction are right.
Mike
Post #565624 27th Aug 2020 8:43am
Oddvar.L
Norway
Pretty sure. Should have generated this sound at warious speeds with low throttle setting then.
Thanx for Your reply🙂👍
Post #565663 27th Aug 2020 2:19pm
cass
I would say don't panic too much unless the noise gets worse quite quickly or you start to get "restricted performance" or fault messages.
I've got a 2007 TDV8 with almost 160,000 miles and there has been a bit of turbo whistle for at least 30,000 miles that I know of and it doesn't seem to be getting worse (or maybe my hearing is getting worse!).
Post #565682 27th Aug 2020 4:21pm
Oddvar.L
Norway
Thank You for reply. No black smoke or any signs of reduced performance. Will check intercooler/turbo hoses as a matter of course. Is there any tendenses for witch hoses usualy goes wrong?
Post #565751 28th Aug 2020 10:29am
