Home > Maintenance & Mods (L322) > Bolt Sizes - A Little Help Please.
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Just changed both front sidelight bulbs. First time I've had occasion to change any bulbs and, whilst doing this, I found that some id10t had not bothered to replace either lower headlight cluster securing bolt.
I assume that the missing bolts are the same as those used to fix the top of the headlight cluster. They are 10mm Hex headed, coarse thread with a tapered end (like a self-tapper but with a bolt head).
Does anyone happen to know any part number or purchasing source for these bolts please?
Many thanks.
Post #565773 28th Aug 2020 12:29pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Toolstation https://www.toolstation.com/techfast-hexwa...gJi_vD_BwE
Post #565782 28th Aug 2020 1:47pm
AJGalaxy2012
Do yourself a huge favour, go onto that well known auction site and look up ''hex head self tapping screws stainless) buy a selection including washers and it will make your life so much easier. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #565806 28th Aug 2020 6:42pm
Gyre8
Thanks both.
@ AJGalaxy2012: That's a good idea. I've had a look but I'm getting confused with the A2/M5/M3 etc. etc.
Anyone know which ones I should go for?
Post #565812 28th Aug 2020 7:55pm
Pawl
Definitely not a self-tapper !
I think the actual fasteners should be cross head screws with an integrated washer - M6 standard thread x approx 15mm long
I can't remember mine having an external hex head as well as the cross head screwdriver drive, but its possible as my memory isn't great - lol
You may find Halfrauds have a M6 x 15 or 20mm long cross head screw in their small packets Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #565813 28th Aug 2020 8:46pm
