![]() | Home > Technical (L322) > Webasto query |
B100 Member Since: 06 Jun 2017 Location: Bedfordshire Posts: 31 ![]() ![]() ![]() |
Where is the Webasto fuel pump (dosing pump) actually situated on a TDV8 ? |
Excellent. Thanks Richard. |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1197 ![]() ![]() ![]() |
Let us know what you're up to |
It's the usual story with a Webasto. It doesn't work. It did work briefly when I got the car 3 years ago, but I've just got around to thinking what to do about it. Because the car is so well insulated, I can't hear the dosing pump clicking - so the first job is to make sure it's working. I have a spare connector which I will couple up to another power source if necessary. If the pump works, then I will take the Webasto out to see just how much carbon build-up there is and how much I can clean out. The aim is to have it powered up remotely via a £14 GSM switch - something that I've done on a Defender and with great results.
Is this any help?
Thanks Richard. I've not seen that thread before. I've been wondering about straying into the laptop testing territory but, being old school, I can't really justify buying a laptop just for this. I've played around with four Webastos recently, using one as heaters for an outdoor pool. The 5KW output brings a 15' diameter pool (with 2" of foam insulation on the top) up to 35 degrees in 24 hours. Warm enough for babies to swim.
Cracking info B.
