![]() | Home > Technical (L405) > IIDtool and software updating - anyone taken a brave pill? |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 366 ![]() ![]() |
According to my IIDTool my car has updates pending for the majority of the modules it can see on the car. Has anyone updated them via IIDTool?
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4345 ![]() ![]() ![]() |
If it ain't broke don't fix it I say |
Thats what I've been thinking for the past year but I'm now thinking what am I missing? do I get anything? what is improved?
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1464 ![]() ![]() ![]() |
It works fine, I had no issues on my L322, I did however connect my CTEK charger to the battery just in case it took a while. When I did a similar upgrade to my Touareg it took nearly 90 minutes! The last thing you want is a low voltage shutdown mid update. BMW i3 Electric Car
I did quite a few things on both of my previous L322's updates and tweaks. It's the L405 and its highly strung modules that put me off. Current
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35833 ![]() ![]() |
you also have to consider the cost, if GAP have that particular ecu update then thats £25 ,
I was quoted £330+VAT to do the update that I purchased from GAP for £25. Great service, great support, Land Rover appalling support as usual, pay to have problems resolved that were there by design. BMW i3 Electric Car
On Supply Mode or normal charge? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
RRYorks Member Since: 13 Jan 2020 Location: Yorkshire Posts: 52 ![]() ![]() ![]() |
I updated the suspension compressor (trying to rectify an fault that turned out to be nothing to do with the compressor) and it promptly bricked the ECU, the car went onto it bump stops. It would not re flash! However, some emails with Patrick at GAP resulted in some updated files that got it up and running again, excellent service from Patrick 2018 4.4 TDV8 |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 235 ![]() ![]() |
These vehicles are very power hungry when the ignition is on (which it will be whilst a software update is in progress).
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1863 ![]() ![]() |
JLR specify a minimum of 100A supply while reflashing L405 etc, soon to rise to 125A
