Home > Technical (L405) > breaking every USB plugs in the central console
karba78
France 2013 Range Rover Autobiography 5.0 V8 Baltic Blue
Hello
i am using 12V to usb cigar lighter plugs as i guess every one
works fine in the central console, the two at the rear and in the boot
but the one near the fridge breaks/kills every one of those i plugged in
i checked, with a meter, i indeed have 12V i am lost
did this happened to any of you
also do you know how the plate with the usb,cigar plug and audio input can be remove
i would like to replace the cigar plug by a usb plug like one of these
https://www.ebay.co.uk/itm/Chargeur-de-voi...SwGEJce-6h
but dont want to break anything while removing the panel
thks 2013 L405 V8 5.0 Aspirated Autobiography
gone 2005 LR3 V8 4.4 HSE
1999 TD5 Defender
Post #566948 12th Sep 2020 7:34pm
that little usb/socket console prises up from the front if i remember correctly....use a screwdriver to help it up/out..
Post #566962 12th Sep 2020 9:43pm
karba78
Thks Stan
will try tomorrow Smile 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #566963 12th Sep 2020 9:57pm
charlie croker mk2
If you overload it by taking to much current the can bus will shut it down , even though it is only on with the ignition .
What are you charging ? the USB connectors are not high power and will not charge a modern phone such as a samsung s20 etc .
Ultimate solution is this
https://www.amazon.co.uk/gp/product/B0852B...&psc=1
Post #567078 14th Sep 2020 11:04pm
