Home > Maintenance & Mods (L322) > LED Lights
Simon_CSK
United Kingdom 2008 Range Rover Vogue TDV8 Adriatic Blue
LED Lights
On my 2007 TDV8 someone has upgraded the lights to LED lights. It is currently in for the MOT and the lights are flickering all over the place. I suspect a bad job at fitting them.
Can anybody tell me the solution? To me there is a resistance problem with the LED drawing less power than the tungsten causing the computer to go into melt down.
Thanks Current cars
Range Rover Sport HSE TDV8
Range Rover TDV8 Vogue
Range Rover P38 Vogue
Range Rover CSK
Discovery 3 HSE
Post #567223 16th Sep 2020 10:35am
You might need to turn off cold and hot monitoring on the bulbs you've changed. Got - 2017 SDV8 Autobiography in Loire Blue
Post #567225 16th Sep 2020 10:46am
Simon_CSK
Is that a software issue?
Does it need plugged in to do that? Current cars
Range Rover CSK
Discovery 3 HSE
Post #567241 16th Sep 2020 12:44pm
The IID tool can do it Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #567253 16th Sep 2020 2:15pm
Bloke
Scotland 2009 Range Rover Vogue TDV8 Buckingham Blue
£500 tool to possibly fix a bulb issue. Rolling with laughter Either get better quality LEDs or junk them and go back to filament bulbs.
Post #567281 16th Sep 2020 8:38pm
It does a bit more than fixing bulb issues but you get what you pay for Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #567285 16th Sep 2020 11:13pm
ultron
Germany 2008 Range Rover Vogue TDV8 Java Black
hi,
can someone tell me where I can find the point in the menu of IID-tool "turn off cold and hot monitoring for the rear lights"
I only find it for the brake lights.
I think I cannot select or see the complete ccf list ..
many thanks
Post #567881 23rd Sep 2020 10:05pm
