Home > eBay & Bargain Spots > external oil removel pump @ £9.99
https://www.lidl.co.uk/en/p/car-essentials...ump/p35314
Post #567446 19th Sep 2020 11:00am
D3Jon
Great spot and a good price, considering you can take it back to Lidl's should it fail. Smile
I recently bought something very similar off Ebay and it's probably worth mentioning that these pumps are slow when pumping oil. The specs on this is engine oil pump rate of 0.2l/minute, so to suck 9L out of a TDV8 would take around 45 minutes.
Useful for many many jobs though, such as transferring ATF when doing a gearbox service, or removing fluids from a hard to reach spot (such as my A8 power steering reservoir which is buried low beneath a lump of a V8 Diesel)!
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #567467 19th Sep 2020 1:18pm
Weegie
Bought one from Lidl over here. Wasn't overimpressed for handling oil. John
GAP iiD BT-Sold
Post #567471 19th Sep 2020 2:13pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Don't use it to refill gearboxes! Use manual pump only. Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #567534 20th Sep 2020 12:44pm
D3Jon
Why? Surely it's fine for (thin) ATF fluid, I'm not thinking of doing it with Hypoid 90!
I have a syringe, but putting in 5 litres with a syringe and it running all over the place and down my arm doesn't seem like fun, but with the pump stuck into a 20L container of ATF and a simple on off switch seems a whole lot better to me?
2014 Disco 4 HSE
Post #567538 20th Sep 2020 2:27pm
appj62
The electric pump was a disaster. A little spilt oil goes a long way on the drive. The manual pump (Draper) didn't take that long and was a lot more controllable. Previous cars:
Galaxy 2001-2007
Fiesta 1984 - 1987
Post #567582 21st Sep 2020 9:09am
D3Jon
OK, thanks for that advice Thumbs Up
2014 Disco 4 HSE
Post #567604 21st Sep 2020 12:30pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
I use a pump up weed killer sprayer for diffs, transfer box and gear box.
Jim
Post #567611 21st Sep 2020 1:42pm
D3Jon
That’s a good idea, so long as the seals are nitrile / oil resistant and won’t disintegrate later from handling oil.
2014 Disco 4 HSE
Post #567972 25th Sep 2020 9:39am
