Home > Technical (L322) > FBH pump affecting engine running temp
Ianb4310
Hi
I have a 2006 TD6, the FBH pump disintegrated while I was changing some airline with a hole in it I’ve capped the fuel lines off are they dealer part only?
Also since doing this I’ve been out in the RR and noticed the engine temp doesn’t get much past the blue section? Is that related to the FBH pump removal or just a coincidence and the thermostat has failed??
Many thanks
Ian
Post #567578 21st Sep 2020 8:07am
