Home > Technical (L322) > FBH pump
Ianb4310
FBH pump
Has anyone found a different supplier other than Land Rover for the FBH pump ??
There’s loads on eBay that look the same is it it just a case of swapping the electrical connector to make it fit ??
Post #567645 21st Sep 2020 7:56pm
Ianb4310
Does anyone know what type of electrical connector is fitted to a 2006 TD6 FBH pump? Land Rover want £112 !!
There’s lots of other webasto dp30 dosing pumps available for a graceful the price just not sure about the connector!
Any help please?
Post #567714 22nd Sep 2020 12:57pm
This is the only image I can find in RAVE:
Looks like a two pin rounded one.
They don't show a photo in the electrical connectors section (should be C0920) .
Post #567718 22nd Sep 2020 1:29pm
Martin
Site Admin
L322s have a Thermo Top Z/C and a DP30 type pump, and use the rectangular type connector. Available in our very own site shop Cool
https://www.fullfatrr.com/shop/fbh-fuel-pu...0-p90.html
https://www.fullfatrr.com/shop/fbh-fuel-pu...-p105.html
Post #567724 22nd Sep 2020 2:43pm
^^^^ Thumbs Up .
Post #567728 22nd Sep 2020 3:59pm
Ianb4310
Martin Sorry to sound a little stupid !!! I just to make sure I’m right in my thinking if I get the of the pre-crimped piggy back connector you’ve put a link up to and any dp30 pump like this one
Cut the old connector off the car then attach the new connector plug in and hey presto!!!!
Post #567745 22nd Sep 2020 5:30pm
Martin
Site Admin
You don’t need the connector, the L322 is already fitted with that type of rectangular plug for the FBH fuel pump.
Post #567746 22nd Sep 2020 5:31pm
Ianb4310
So plug and play then happy days!! Does dp30 refer the the flow rate ?
Post #567747 22nd Sep 2020 5:35pm
