Home > Technical (L405) > E85 in flex fule supercharged 5.0l V8
hari2m
United States 2015 Range Rover 5.0 SC V8 Mariana Black
Hi my RR said I can use felx fuel in it at the fuel cap. Thought it would work with E85 (heard it runs clean). After riding for a while the engine started to miss fire and the check engine light is blinking. Did anyone own a RR with felx fuel and tried it?
Post #568034 26th Sep 2020 5:44am
karba78
France 2013 Range Rover Autobiography 5.0 V8 Baltic Blue
i had my v8 4.4 remaped to accept e85, did 100 000 km without any issues, except harder to start during cold mornings
if you remap it, it will run, and no orange light
the orange light appears because the ignition timing is not optimum and the lamdba sensors detects anomalies with non optimally burned gasoline 2013 L405 V8 5.0 Aspirated Autobiography
gone 2005 LR3 V8 4.4 HSE
1999 TD5 Defender
Post #568071 26th Sep 2020 6:59pm
hari2m
I just got the scanner hooked to the RR and I was able to pull the codes.
It gave below codes and details
Primary code: P0300-> Missfire on multiple cylinders (Driving cycle C)
Stored codes: P02F1-> Fault code F1H: signal out of range - below minimum
: P0304-> Cylinder 4 Missfire detected: Last occurrence - minimum signal
: P1315 Persistent missfire
: P0307 Cylinder 7 missfire
I feel like there are two possible reasons.
1. E85 started to dissolve the gunk that was formed by the regular fuel. Now the gunk might have blocked the fuel injector.
2. The engine was running when the gas was filled (Yes I did left it running and this is the first time) and this caused the dust to lift and reach the fuel injector which is the least possibility cause there will be a filter around the pump.
I am mostly leaning towards the first case. Is there a way to clean the injectors from the blockage without pulling it out? If not then how long would it take to pull the injector out.
Post #568095 27th Sep 2020 2:53am
karba78
you can try mecacyl
i did that just after my remap and it helped clean the injectors
https://www.mecacyl.com/en/accueil/70-meca...papes.html 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #568106 27th Sep 2020 9:13am
Dixy
2016 Range Rover Vogue SDV8 Loire Blue
Do these snake oils actually do anything letters not necessarily in the right order
Post #568117 27th Sep 2020 10:52am
karba78
worked really well for me
my car would start difficulty when cold
using half a bottle with a full tank of petrol changed completely the car start
can't judge the rest: but that yes worked 2013 L405 V8 5.0 Aspirated Autobiography
1999 TD5 Defender
Post #568118 27th Sep 2020 11:14am
hari2m
I live in united states so, I couldnt find mecacyl. But I just did a fill up with a fuel injector cleaner added. Will see how it goes. Thanks for the response.
Post #568204 28th Sep 2020 4:14am
hari2m
So finally, the misfire is gone and the check engine light is also gone. I am gonna add another tank of fuel with the injector cleaner and see how the engine runs.
Post #568845 4th Oct 2020 4:58am
