Home > Maintenance & Mods (L322) > Jack adapter for Mercedes Vito jack
Glibbs
4.2 SC - Could anyone point me in the right direction please where I can buy a part that would go between the jack and the jacking point?
TIA. Range Rover 4.2 SC
2 Range Rover Classics - one from new but both rusty now.
Rover 3.5 Coupe had since new.
Subaru Legacy 3.0.
BMW K1200RS.
Post #568123 27th Sep 2020 11:00am
GGDR
There isn't a part off the shelf that'll do it
These need drilling to fit your jack:
https://www.ebay.co.uk/itm/For-BMW-MINI-CO...2749.l2649
Seems the cheapest around at the moment but it's not UK stock.
. Cheers, Greg
Post #568125 27th Sep 2020 11:23am
Glibbs
Many thanks. I've seen these but my skills are sadly lacking in that regard. . . Range Rover 4.2 SC
Subaru Legacy 3.0.
BMW K1200RS.
Post #568126 27th Sep 2020 11:26am
Strider
I bought one from Creationmotorsport at £10.99 (PRODUCT CODE : AL0111) , do a search for mini jacking pad.
Im sure your local garage or a workshop would drill the single locating hole and another at right angles
to hold it on for a small fee.
Post #568131 27th Sep 2020 12:39pm
JoolsB
United Kingdom 2012 Range Rover Vogue TDV8 Buckingham Blue
I’ve just ordered a couple of the rubber ones to see how they work, will let you know when I get them.
Post #568132 27th Sep 2020 1:32pm
Range Rover L322
I think the Mercedes Vito jack is a scissor jack as below. The drilling GGRR (Gary) is referring to is for a Mercedes Sprinter Jack which requires this mod here: https://www.fullfatrr.com/forum/topic14177...ottle+jack
.. there is a general consensus scissor jacks are not great for Range Rovers, maybe the Vito jack is more substantial than the original RR scissor jack but the jacking points being inboard, weight and the small fulcrums all work against scissor jacks. There has been mention of scissor jacks collapsing under a Range Rover on level ground too. A bottle jack with a pedestal is generally considered preferable. Hope that helps!...
Mercedes Vito Jack:
Post #568166 27th Sep 2020 7:05pm
GGDR
GGDR = Greg Cheers, Greg
Post #568196 27th Sep 2020 8:56pm
