Home > Technical (L322) > 2004 FFRR binnacle display language change?
Zigzagsky
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
The speed camera issue is quite common. It's down to the fact that the discs with this enabled are not OEM but modified to show speed cameras. The problem is that the mod uses one of the language 'sets' so is done against the English set. If you disable them then you are actually selecting a different language set which is the French one. 2005 Range Rover L322 TD6
2009 Jaguar XK 5.0 Portfolio
1969 Jaguar E Type Series 2, 2 Plus 2
Post #361229 9th Dec 2015 10:47am
jakebullet64
United Kingdom 2003 Range Rover Vogue 4.4 V8 Santorini Black
cheers for the response and the clarification chap.
I'm sure I can live with the speed camera alerts and keep the English language.
jake 2003 Range Rover Vogue 4.4 on Gas
1961 88" 2.25 diesel - George
Gone - 1997 3.9 V8i Discovery - Burt
Post #361583 10th Dec 2015 10:11pm
jjcbollen
Netherlands 2003 Range Rover Vogue 4.4 V8 Java Black
Though this thread is quite old, the problem where the language turns to French is caused by the onboard computer settings.
When you turn "speed camera" to off you activate the French language for the message screen. (French = 2, english = 1, and the choice to activate or disactivate speedcamera alerts chooses either one of these sets and thereby activating the other)
Post #391947 16th Jun 2016 9:24pm
Jimmy C
United Kingdom 2003 Range Rover Vogue Td6 Zambezi Silver
This also happened to me when i installed the MK4 sat nav, enable alerts and back to english
Post #392014 17th Jun 2016 12:57pm
p38arover
Australia
jakebullet64 wrote:
also, the menu has 'memo'. Once activated it sets a beeper / alarm off at 1959hrs, whoopy Rolling Eyes
Aha! I wondered why mine sometimes did that and other times it didn't. It's annoying so I'll turn memo off. Thanks for that.
OH, mine did it every hour at nn59. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #392015 17th Jun 2016 1:04pm
Rangeyman
Mine has done this twice in 3 years but goes into German not French.Went into menu and messed around until I found language and changed it to gb,a little tricky when it is all in German !It has also recently decided to change temps from centigrade into Farenheit but I don't know how to get that back as yet !
Post #392050 17th Jun 2016 6:18pm
jambo27
The temperature unit is changed in the setup menu on the sat nav - its on the same screen as the fuel consumption units l/100km, mpg etc etc. 2008 TDV8
Post #392076 17th Jun 2016 8:31pm
