Home > Technical (L322) > Rear suspension bushings
ebajema
Gday gentlepeople, another question!!! The RR failed entry registration again on two suspension bushing (upper rear arms). Does anyone know if those are the same as the 2006 model (mine is 2010) as I have a set lying around that I bought for my old 2006 model. MY 2010 5.0 SC Galway green and sand interior!!
Post #568307 28th Sep 2020 8:16pm
Classic888
Hi.
If you mean the rear upper INNER bushes then according to the parts guide they are the same. Part number is the same, RGX000080.
Same for all L322 from 2002-2012.
Regards.
Post #568353 29th Sep 2020 10:50am
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
according to this page the cost of these varies between 3.93 - 70.57 Shocked Shocked
https://www.brit-car.co.uk/product.php/449...over_vogue
Post #568368 29th Sep 2020 4:02pm
ebajema
Thanks all, I have found a supplier that has genuine in stock and have ordered them. Next week when I'm back from skiing holiday, I will get them installed as well and hopefully finally get it registered.
I have a complete set of bushings originally for my 2006 SC but if I remember correctly only the front and I ended up putting the complete arms in it, was easier for our mechanics in Nigeria. MY 2010 5.0 SC Galway green and sand interior!!
Post #568407 30th Sep 2020 7:08am
GraemeS
Australia
The top knuckle bush RHF000260 on both sides of mine needed replacing some time ago.
Post #568409 30th Sep 2020 8:40am
ebajema
Thank Graeme!! I found genuine bushings with the Britpart rep here in NZ. They also got me the entire drive train fluids and gearbox filter and ATF (ZF OEM). GBP 50 each.
Got it booked in for next week to get that done! MY 2010 5.0 SC Galway green and sand interior!!
Post #568486 1st Oct 2020 10:24am
