![]() | Home > Technical (L322) > L322 Reservoir pressure drop |
S.Hafsmo Member Since: 02 Oct 2018 Location: Nordland Posts: 170 ![]() ![]() ![]() |
From what I can see from online system drawings, it should only be pressurised up to the valve block attached to the reservoir. Though it would be useful to know where the pressure sensor is located. Anyone? 2007 L322 3.6 TDV8 Stornoway |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
The relief valve/sensor is on the rear end of the reservoir.
I do not see how a failing compressor should result in reservoir pressure drop, as these are segregated when the compressor is stopped.
RR2B Member Since: 04 Aug 2020 Location: Rowlands Castle Posts: 262 ![]() ![]() ![]() |
Resurrecting this thread, anyone know what gauge steel the air reservoirs are constructed from? Quite a bit of corrosion on mine - would be good know how much corrosion can be tolerated before it's likely to start leaking. 2011MY 4.4TDV8 Autobiography Baltic Blue
