![]() | Home > Technical (L322) > Battery failure on its way? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35779 ![]() ![]() |
the older FF's are indeed heavy on the batterys and 4 years worth aint to bad.. ... - .- -.
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3980 ![]() ![]() ![]() |
Before you go out and buy a battery it would be useful to check the alternator voltage if you can. Should be at least 14.1V when on a run. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6823 ![]() ![]() ![]() |
You really don’t want it to be the alternator |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1901 ![]() ![]() ![]() |
Yes I do not want a new alternator, water cooled, a pain in the a*** to change never mind the cost.
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 ![]() ![]() ![]() |
Sure I read somewhere in the past that's it's recommended to fit a new battery every 3 years. |
I’ve had 3 during my tenure of 8 years. Got - 2017 SDV8 Autobiography in Loire Blue
so getting 4 years out of this battery is quite good!! |
the brake switch behind the pedal gets stuck so remove and a clean might help... ... - .- -.
I'll check that, im also checking if water ingress on the drivers side over the LCM.
Davlyn Member Since: 21 Nov 2011 Location: Sladesbridge, Cornwall Posts: 236 ![]() ![]() ![]() |
When ever anybody mentions a fault to me with any LR I always suggest checking the battery before anything else. All of them draw so much on initial start up and as you are experiencing unless they get a good run the alternator just doesn't get enough time to chuck all those wiggly's back into the battery.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
Getting to that time of year when the C tek (other makes are available) comes into its own! Previous cars:
An update to close the thread down.
