![]() | Home > Maintenance & Mods (L322) > TD6 gearbox service |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
If you fancy the lazy way, pop over to Suffolk Transmissions at Haverhill & see Paul, he did my X5 [same box] a couple of times for me.
| jim4244 Member Since: 31 May 2012 Location: UK Posts: 855
This is the correct gearbox oil for the GM 5 speed box.
| wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 808
Well worth doing and easy enough as a DIY. I did mine 50000 km after a rebuild and the fluid was no longer clear. By removing the cooler lines you can drain the cooler too or even flush if you are confident and have a willing helper. There is a great video on youtube. Plenty of options on fluid nowadays at least here in Oz I used Penrite Fully Synthetic meeting GM Spec. 2007 TDV8 VSE
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
Would recommend that you get Filtran filter. Original equipment. Don't think the substitutes are reliable. John
| All times are GMT |
