![]() | Home > Technical (L322) > Hybrid TV Unit 2011 Vogue SE/No audio |
dennij Member Since: 24 Feb 2019 Location: Up North Posts: 450 ![]() ![]() ![]() |
I'm not 100% sure but I believe they have to be programmed to your vehicle as they are VIN locked? 2011 TDV8 Vogue SE |
66jag Member Since: 14 Jul 2019 Location: Lancs Posts: 4 ![]() ![]() ![]() |
Thanks, I was lead to believe they were a like for like replacement providing you kept to the same model serial number, as you say that may not be the case given the one now fitted has no audio/DAB/TV output.I was careful to find a unit very close in production number to mine to avoid any compatibility issues but unless there's another issue I'm not aware of perhaps it needs programming. Before I fire the parts/diagnostic cannon I think I'll try a hard reset.... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
do a battery reset to see if it reboots the ecus.. ... - .- -.
Thanks Stan, was just doing the hard reset before I saw your post which has done the trick, all working fine now. |
