![]() | Home > Technical (L322) > Misfire on all cylinders, random misfire, misfire at startup |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 697 ![]() ![]() ![]() |
Coil packs would be my first starting point? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Ian928 Member Since: 16 Aug 2016 Location: Kristiansund Posts: 80 ![]() ![]() ![]() |
I have been thinking about that, but is there anything that can kill all coils? I have checked codes twice, and the only Cylinder that I have not had misfire on is no 3.
Personally, I would say a misfire is more electrical than fuel........happy to be proved wrong.
I have changed the spark plugs, they did not look good, but it made no difference to the misfire.
I'm going to stick my neck on the block & go with coil pack[s].
Thank you, I will try to change the Coils. I have searched and learnt about possible failures and I think that anything fuel related should throw a code.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2241 ![]() ![]() ![]() |
Hi Ian
Classic888 Member Since: 10 Jun 2015 Location: East Yorkshire & Hertfordshire Posts: 233 ![]() ![]() |
When you filled the fuel tank up did it show it was full on the guage? |
RRDunc Member Since: 26 Feb 2020 Location: Leicestershire/Warwickshire border Posts: 520 ![]() ![]() ![]() |
Sounds similar to issues I had on my Audi A8. Turned out to be coil packs failing. Because they were the same age they all went at pretty much the same time.
Thank you for sharing your findings with me, I appreciate the time you spent to decribe it!
2006 Supercharged |
Just pmd re cat but I doubt it’s all the coils but intrigued to find out! Current stable:
Thank you all! Today we changed all 8 coils, and now the car is like new again! So, if you have misfire and no other error codes, it is probably best to start with the coils 2006 Supercharged |
What mileage was your car? Did you have a slightly lumpy idle before do you remember? How is your idle now? Current stable:
Also did this fix your lamdba/ o2 faults? If you had one bank not firing at all it would mess up the values for sure Current stable:
