![]() | Home > Technical (L322) > Air Con doesn’t seem to be working again |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 627 ![]() ![]() ![]() |
Just had my ac sorted and although it was a saga the original issue was the compressor - the solenoid as you say. Compressor was actually in v good condition but you cant buy just the solenoid. Obviously mine is a later SC but I doubt the ac would vary between models - its still got to cool the same volume of space inside. Mike - MPx
HS66 Member Since: 22 Jun 2016 Location: Surrey Posts: 73 ![]() ![]() ![]() |
Oddly the compressors do look different from the pictures I’ve seen between the 3.6 and 4.4 I’m not sure if the SC has a different one too?.
Well I was obviously way off! |
I couldn’t get it on the machine at work today but did put a rudimentary gauge on it from one of the bottles which people have to gas up yourself (I didn’t add any gas at all)
Plugged in machine again today and it only has about 20g of gas left in it, down from being refilled from 750g a couple of weeks ago.
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 373 ![]() ![]() ![]() |
Mine had a leak on the high pressure side from where the pipe is fitted to a plastic clip. Best way to find it is to put dye in it and look with a UV light 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Tooltime79 Member Since: 03 Jun 2015 Location: York, North Yorkshire Posts: 27 ![]() ![]() ![]() |
I had a leak in a pipe at the front of the engine which had been rubbing against the earth strap. Have a look at this post:
