Home > Technical (L405) > Electric rear seat folding -
HDFB110
United Kingdom 2019 Range Rover Vogue SDV6 Santorini Black
Bench type rear seat (not executive)
Being a taller person I have the driver seat as far back as it will go on it travel.
I understand that if I activate the rear seat fold (either part 60 or 40) it will detect that the driver seat in a position for potential clash & move the seat base forward & tilt the recline forward.
It will then continue & finish the fold function.
Great -
But what happens to the front seat -
Does it return back fully to its original setting - I don't mid if I have to reselect my stored memory.
As long as it goes back to where I want it.
I am hoping that when the rear seats are folded I have to then drive in an uncomfortable position?
Thanks
Post #570381 20th Oct 2020 11:58am
Martin2
I've got the Executive seats, so they may be slightly different but the seat moves back as far as it can when the seats are folded. In my case, that's slightly further forward than my normal seating position, but not much. MY23 Panamera E-Hybrid
MY19 SDV8 Autobiography - Sold
Post #570384 20th Oct 2020 12:30pm
HDFB110
Thanks for that -
I'm use to a Disco 5 - the headrests fold down on that so the fold happens with the front seats staying where they are.
Which is ideal/right/best.
I often travel with the rear seat folded - OK maybe just one side - but I don't really want to sacrifice front seat comfort & position to have the rear seat folded.
I have ready that the non electric/standard rear headrest can be removed easily so may be that would be the answer.
That will give more space - however I don't know what triggers the potential clash position.
There must be others out there of a taller stature that have experience with this ????
Post #570386 20th Oct 2020 12:37pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
My assumption is the clash position is a programmed position based on the rear head rests being at their highest point. The photo below shows mine once the seat has folded back - the system leaves loads of space as my drivers seat was much further back than that before the rear seat folded. However with the rear headrests at the lowest point on the seatback I can then move the drivers seat back almost all the way (bar about 1 - 2 cm) using the seat controls.
. - apologies for state of car - it badly needs a valet!
From the 2016 manual it mentions this clash position
Intelligent seat cargo mode is used in vehicles with powered front and rear seats. Intelligent seat cargo mode allows the user to fold and unfold the rear seats, avoiding a clash with the front seats.
The front seats move slightly forward if there is a likelihood of a clash when folding or unfolding the rear seats. When the fold manoeuvre is complete, the front seats return to their original position, or as close as possible if a clash condition still exists.
After the rear seats begin to fold, they may stop moving to allow the front seats to move to a safe position. Should this occur, keep the buttons pressed or the front seat movement will stop. As soon as the front seats are clear, the rear seats will resume the fold manoeuvre.
The front seats only move if the vehicle is stationary.
The driver's seat only moves if the transmission is in Park (P).
Front seat movement can be cancelled at any time, by pressing any of the front seat switches. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #570395 20th Oct 2020 1:57pm
HDFB110
Thanks for the picture - looks as if (as you) the driver seat can go back almost to its furthest position.
If not looking at that if the headrest is removed there would be stacks of space.
Certainly something for me try during a test drive -
Its just one of those things that is important to me but may be not to the next 100.
Thanks again - - - -
Post #570396 20th Oct 2020 2:26pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
I am also tall and use the seat almost as far as it will go. I also have bench seats. Most of the time, the front seats just go forward and stay there when folding the rear ones, so I have to press the memory to get it to the driving position. But I would say every 5-7 folds the front seats also go to the memorized position by themselves! I cannot understand this inconsistency... But in any case, even if the front seat is sent to the rear at maximum, it still doesn't touch the folded seat. Of course, the rear headrests have to be pushed in as they are manual...
Post #570402 20th Oct 2020 3:44pm
Flyingfocrs
Scotland 2014 Range Rover Autobiography SDV8 Santorini Black
I’m 6ft4, once fully folded the drivers seat goes back to my preset position.
Not been an issue for me anytime i’ve folded the rear seat.
Post #570486 21st Oct 2020 12:38pm
HDFB110
Many thanks - took a test drive today.
Yes - with the driver seat in my comfortable driving position the rear seat starts to fold then detects the potential clash the front seat then moves both forward and the rake tilts forward once out of the way the rear seat continues to fold.
Once this done by the time I have shut the tailgate and got round to the driver door and opened it the driver seat is back to where I had it.
Checking behind the front seat there is still a small amount of clearance.
Again thanks ———-
Post #570529 21st Oct 2020 5:27pm
fin
Worth noting someone in the future reading this. The 2013-14 cars do not move the drivers seat, you have to do this yourself, everything looks the same but it must be the software.
Post #571866 4th Nov 2020 5:53pm
TwoautobiographyTom
United Kingdom 2013 Range Rover Autobiography 5.0 SC V8 Loire Blue
I am that future person. Thanks for the heads up. Maybe the Gap tool would be able to program this.
Post #638903 7th Aug 2022 10:50am
