![]() | Home > Maintenance & Mods (L322) > About the non-existing gauge in the drain tube TDV8 4.4 |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
I know there is a tube you can connect a suction pump to, in order to get the oil out from above, but I think that has a long steel tube on it.
| AxxA Member Since: 17 May 2020 Location: South Posts: 11
Yes, in theory but... Practically I don't know.
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
The pipe is the suction one for removing the engine oil when servicing. Connect a suction unit with a suitably sized receiver and away you go. There is a drain plug is under the car on the sump and will then only have a small amount remaining when you take it out.
Thanks for your reply rjff, I know about the suction/bolt under the car/dashboard screen.
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
Disco guys have made their own dipstick using this tube. See the sister forum |
Couldn't agree more on checking the oil AxxA, a real PITA.
Thanks for the clue DrRob, you meant his: https://www.disco3.co.uk/forum/emergency-d...l+dipstick (maybe you'll need to be registered to see the topic). |
Yep |
No I won't, but thanks for reminding me.
| t5pete Member Since: 31 Aug 2020 Location: Sheffield Posts: 114
I'm sure some one on here made a gauge out of some wire.
In fact, if if if... if I can have a constant measure:
| Discotigger Member Since: 12 Feb 2013 Location: Cumbria Posts: 804
Is there a way to get the Oil Level on the TFT when the engine is warm / up to temperature. I only get the Oil Level when the engine is cold, won't show a level on the service menu once you have started the car and run the engine.
| Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3887
https://www.fullfatrr.com/forum/post569349...031#569349
So, read when cold or Read 20min after shut down of a hot engine. Simples. You can over ride Unavailable messages any time with bonnet open and press cruise cancel twice when the message pops up saying unavailable but readings won’t be as accurate naturally. That’s it. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years I use www.glenrands.co.uk Great independent specialist! -------------------------------------------------- |
| All times are GMT |
