Home > Maintenance & Mods (L322) > Retrofit LED main beams
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
I'm assuming I might be late to the party on this one, but I see Osram produce a retrofit LED replacement range that includes H7 fitment (ie L322 main beams). Reading the blurb they look brilliant, banging on about how much better they are than normal bulbs in your healdights etc., then they tell you that they aren't ECE approved and can't be used on the road in the UK, WTF is the point of making them then?!
Clearly, they are going to be used on the road, and given they would be main beam only, I can't see why that would be a problem. Does anyone know if they are a direct replacement and don't either blink or throw a bulb failure error? Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #570811 24th Oct 2020 1:10pm
some have done this mod..... here's a few threads re this,
https://www.fullfatrr.com/forum/topic43091.html?highlight=led+h7
https://www.fullfatrr.com/forum/topic44504.html?highlight=led+h7
https://www.fullfatrr.com/forum/topic40893.html?highlight=led+h7 ... - .- -.
Post #570815 24th Oct 2020 2:11pm
rvbush
Thanks Stan, much appreciated. Drives:
Post #570824 24th Oct 2020 4:05pm
