![]() | Home > Technical (L322) > Fuse 57 |
Gr4h4m Member Since: 08 Oct 2020 Location: Chester Posts: 88 ![]() ![]() ![]() |
I’m going to have a look at the weekend to see it anything is untoward. |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 186 ![]() ![]() ![]() |
Hi, I have the same issue in that I have no front map lights. Also have no heated rear seats working which I'm sure is linked to the battery saver system ie the car has switched off the seats to protect the battery. Once had a battery drain and noticed the map lights were on and the rear heated seats started to light up and work ! Charged the battery up and no rear heated seats and no front map lights ! I'm sure it's an earth issue and don't think it's a common problem. |
Was your fuse 57 blown? |
hi
Well I have checked and replaced all of the bulbs in the car and the fuse. It all seems to be ok? I can’t see anything dodgy so will have to wait and see. |
