Home > Technical (L405) > Stop - start, preserve battery
cxdood
United States 2016 Range Rover HSE 3.0 SC V6 Santorini Black
I have a 3.0 V6 supercharged petrol in the USA. 2016. According to another thread some 2016 models do not have a secondary battery used for stop start. How do I find out if mine does?
My stop start very rarely engages. It can be an annoying feature on other cars - but on this one it has happened so rarely that it hasn't annoyed me yet. In some cases when otherwise just sitting idling I would mind it working. I went to a drive in cinema and had the engine running because I was nervous about the battery being run down from running the sound system for a long time. I could have had just the ignition on, but wanted to be sure to have enough electricity to turn on the engine again. I would expect the stop start to engage in that situation, but it never did. Just parked in P with parking brake on and engine turned on.
Do you know if the L405 has a way of preserving electricity to always be able to start? Will a secondary battery for stop start make the car always be able to start?
Post #571339 30th Oct 2020 6:49pm
yours might have a secondary battery or most likely a capacitor for the stop/start..
take the right side (as you look into the load space) panel off and see what you have...
personally i dont like the stop/start so i have disconnected mine... ... - .- -.
Post #571343 30th Oct 2020 7:46pm
funnyguy1
United States
Hi Stan,
How did you disconnect the start/stop? I always turn mine off 1st thing but I would like to disconnect it. Mine is a 2016 SC. Thx!
Post #576413 17th Dec 2020 4:08am
if you have a secondary batery then you disconnect the earth to it, if a capacitor then diconnect the signal wire to the VQM [voltage quality module]
https://www.fullfatrr.com/forum/topic52063...stop+start ... - .- -.
Post #576416 17th Dec 2020 9:40am
