![]() | Home > Technical (L322) > Lack of power / poor fuel economy? - Possibly fixed |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1041 ![]() ![]() |
I would be checking your egr valve 1st off looking at that and ur turbo actuator isnt jammed up |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 855 ![]() ![]() ![]() |
EGR has been blanked Dave. That was one of the first things I did when I bought the car.
No idea jim mines a v8 petrol but have a look via the search function and look on tube you
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
Check for boost leaks on hoses etc, performance and fuel economy will go out the window from a small leak. |
Hmmmm.... I can’t see any splits or holes.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
Have a look at the Vacuum unit and solonoid hoses for leaks especially at the ends, one goes down to the turbo.
Wayneg you are a star!
Glad to be of help and thanks for the thanks. As you can see on my car the exact same vacuum hose has failed and I changed it to red silicone. If there is enough slack it's easy enough to nip 1/4" of each hose for a tighter seal. 2007 TDV8 VSE
