Home > Technical (L322) > 8 speed gear selector stuck
tractorfactor
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Zermatt Silver
Hi All,
The rotary gear selector in my 2011 tdv8 decided to stay in reverse this weekend.
I was actually in low box reversing my trailer when it happened.
Went to put it into drive and nothing, locked in reverse.
IID indicated a gear selector solenoid lock failure.
Eventually I had to switch the car off.
Then I couldn't start it because it was in gear.
Had to leave the car stranded overnight.
I got the module out and stripped it down.
Solenoid works fine powered off a 9v supply so must be on the board or other fault.
Rebuilt unit back into park, and managed to start the car but no gear selection.
At least I got the car home via a tow and the transmission release lever.
Every day is a school day owning a RR!
I see a number of evoke and velar owners have had the same issue.
Anyone had similar with this box set up! Is it just a case of replacing the unit or does it have to go into the dealers?
I'd rather do it myself as not got a lot of positive things to say about my local main dealers unfortunately.
Cheers, TF
Post #571563 2nd Nov 2020 11:56am
GraemeS
Australia
Are you accustomed to holding the foot-brake applied with the gearbox in any position where the brake pedal must be pressed to change in 1 direction or the other, eg reverse to park, for more than just the short time to rotate the selector, thus keeping the lock motor powered for more than a couple of seconds?
The selector module uses a 1 ohm resistor to monitor the lock motor and if the motor is powered for more than a short period then the resistor will get very hot and melt the solder causing the resistor to no longer be attached at both ends or 1 or both joints becoming high resistance, thus cutting power to the lock motor. A fault code will occur for a short circuit on the lock motor but the fault is actually open circuit. The resistor can be re-soldered with a fine point soldering iron that is set to get hot enough to melt the lead-free solder.
Edit: Reversing with the brake pedal even lightly pressed will cause the lock motor to be powered so if done for more than a short time will cause the problem. The circuit board would do well to have a remotely mounted much higher wattage resistor.
Sometimes a burn mark can be seen around this resistor.
Post #571638 2nd Nov 2020 8:58pm
tractorfactor
thanks for that info,
I have had the board out, but no obvious signs of burning around any component.
However I will check the resistors out again. Any idea of where the offending resistor sits on the board?
Cheers. TF
Post #571677 3rd Nov 2020 7:18am
GraemeS
Australia
Here's a pdf prepared by a member on AULRO (I'll add his name if I can track it down). The last picture has the 1 ohm resistor marked. Sometimes the resistor isn't burnt but re-soldering its ends fixes the problem presumably due to a high resistance joint having developed when the solder melted.
https://www.fullfatrr.com/gallery/albums/u...oblems.pdf
Post #571679 3rd Nov 2020 7:37am
