![]() | Home > Technical (L322) > Heating - starts warm, goes cold |
coopss Member Since: 21 Apr 2018 Location: Hampshire Posts: 281 ![]() |
Right looks like this a mixture of both valve units not working:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
Could just be the fbh changeover valve is stuck, when the fbh is running it circulates through the fbh and heater matrix in the cabin, once the engine is started the valve should switch so the fbh warms the engine too, once up to temp the valve shuts off the fbh side of the circuit and it all switches back to just circulating through the engine to provide the warmth.
Thanks for that info, sounds like the cause to me.
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 250 ![]() ![]() ![]() |
Mine is in my son in law's garage right now with a similar plumbing problem.
That does not sound fun at all.
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
Do you have 4.4 tdv8?
Thanks yep 4.4 tdv8. Very glad to hear it’s more accessible. Is it in the engine bay under the air filter/fuse box or behind the plastic arch liner? 1995 4.6 v8, green/tan (long gone)
The changeover valve would be my first point to check.
Remove the engine cover and follow one of the heater hoses from engine. Will take you straight to the valve at the side in engine bay. |
My symptoms were the passenger side was the only side to get slightly warm. Rear heater was cold and drivers side only very slightly warm. |
Had a go at getting this off but all the pipe clamp points are facing down so can’t get them off. Took the solenoid cover off in situ but can’t get the plunger or plate off - feels like something is holding it in 1995 4.6 v8, green/tan (long gone)
Can you move the plunger up and down? How much movement?
