Home > Technical (L322) > Poorly TD6 |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
i would say those injectors need looking at. they are not coded on them so swap around and verify it is the injectors rather than a electrical gremlin as i know the loom for the injectors can be problematic.
7th Nov 2020 4:44pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
Hmmm...... I see that the injector loom fails in a lot of instances? I don’t know if it will be worth buying and fitting a new loom in the first instance?
7th Nov 2020 5:19pm |
Mads Member Since: 18 Oct 2020 Location: Lommedalen Posts: 8 |
Gotmoat the same values. As Ive heard IId tool is struggeling on the minus / positive readings of the numbers. The injectors with the high numbers can be compensating. Try to mive around, or do a leak test. |
8th Nov 2020 11:04am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
The looms are very easy to test with a multimeter due to the injector ecu being under the bonnet.
8th Nov 2020 12:12pm |
Thanks Paul
8th Nov 2020 1:37pm |
Would it work if I just disconnected the plug to the injector from the injector loom? Then when the plug is disconnected if it makes no difference to the engine note it is either that injector or that part of the loom is damaged?
8th Nov 2020 1:42pm |
Yep, just remove the electrical connector on the injector. It will be either or tbh Jim. Once you've identified which injector is at fault I'd the suggest to check the loom with a multimeter and if that checks out ok, the fault will be with the injector. If it doesn't then you've 2 choices, buy a new loom or repair the one you have. |
8th Nov 2020 2:02pm |
thing is if you remove the injector you will know for sure. You can also get a bottle with a wide neck and visible check how the injector is spraying compared to a good one. simply identify the good injector then plug the suspect one in on the same part of the loom. if it sprays the same you know it is the loom. if it does not it is the injector. then you only spend money on the faulty part.
8th Nov 2020 2:51pm |
Is the loom simply plug and play?
8th Nov 2020 3:44pm |
Yes. You can literally remove it within 30mins. |
8th Nov 2020 4:13pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
As others advised check the loom but before you start spending money pull the plugs off make sure there is no corrosion and the small connectors are not spread open too much. Refit and also give each plug a wiggle with the engine running to see if there is a note change. It's easy enough to remove the loom and also do a continuity test. Shame you are not in Oz, I have a good spare loom. No need to program anything when changing injectors or the loom however you can reset the injector adaptive values with the BMW software so no doubt can do the same with IID tool 2007 TDV8 VSE
9th Nov 2020 1:04am |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Personally, I would not recommend this approach - "playing" with the extreme high pressures encountered on fuel injection systems can be very injurious - the pressure is sufficient to penetrate skin & take eyes out. 2003 Range Rover Vogue TD6 |
9th Nov 2020 11:24am |
Neither would I. Plus you would need to make up some injector pipes as the standard ones won't reach very far... |
9th Nov 2020 11:37am |
If you need to test the spray pattern of the injector it is easy enough to remove the nozzel once the injector is pulled out. I use aerosol brake cleaner aimed into the removed nozzel, the pressure is enough to see the emmiting pattern, it should be 5. Also a good way to diy clean them. I would not recommend this unless you know how to remove the nozzel corectly, its not hard to get right but even easier to mess up a good injector. 2007 TDV8 VSE
9th Nov 2020 12:13pm |
