Home > In Car Electronics (L322) > Reversing Camera Quality - Is This Normal? |
JAYBOY Member Since: 17 Oct 2012 Location: South Wales Posts: 2204 |
Thats not right, could be your camera has gone.
7th Nov 2020 9:23pm |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 |
Before you replace the camera check to make sure that the glass is not scratched/bloomed/dirty - if so, the damage may just polish out.
8th Nov 2020 9:47am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4225 |
Powerful UK now do an upgrade camera 📸 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
8th Nov 2020 10:30am |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3192 |
As Brian says, if you replace the camera NTSC only not PAL or PAL/NTSC. John
warm_rover Member Since: 27 Nov 2020 Location: liverpool Posts: 5 |
I ordered this
27th Nov 2020 7:14pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 843 |
Try turning down the brightness. It will improve the picture no end.
27th Nov 2020 7:57pm |
I fitted it today im pretty impressed with the luxury land rover camera. |
28th Nov 2020 12:53am |
28th Nov 2020 12:54am |
Archieatkins Member Since: 15 Oct 2019 Location: Birmingham Posts: 125 |
Thanks all for the suggestions. This weekend I spent a bit of time cleaning and polishing the camera housing and it has improved to the below. Again with nothing to compare against just wondered if this was the standard quality of image. Would the upgrade from powerfuluk be much of a difference? Aren’t we just limited by the actual quality of the screen?
29th Nov 2020 3:34pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Yes that looks like the normal oem crap image, and no, if you replace the camera with a suitable new higher quality camera the image on the screen improves. |
29th Nov 2020 3:57pm |
