Home > Technical (L322) > Adding remote module for Webasto FBH to 2010 4.4 TDV8
Vogue50andmore
Northern Ireland 2010 Range Rover Vogue 4.4 V8 Java Black
Hey Folks
Before posting is this the right place for FBH matters?
Many thanks
Post #574384 28th Nov 2020 9:54am
Discotigger
Yes, also use the search function on this forum as there's loads of threads on FBH problems. A quick search may provide the answers to your questions. Thumbs Up
Post #574409 28th Nov 2020 2:45pm
Vogue50andmore
Just bought a 2010 4.4 TDV8. I want remote function with a FBH so my mechanic suggested removing the eberspacher from my old 4x4 and switching it for the Webasto. The water pipes are there, fuel line, sounds good in theory. But I don't know if the Webasto just boils water, or engages with HVAC via CAN bus to warm the cabin, if it does the eberspacher won't simply swap in.
The dealer has quoted £150 for a remote module. Simon C on YT does a really simple install using the the headlights to trigger the FBH, I see others do complicated things in the rear avionics area. Just seems inefficient to pull the Webasto when it's working fine.
Thanks in advance.
Post #574455 28th Nov 2020 8:44pm
