Home > Maintenance & Mods (L322) > Rear brake disk joy
Red Hot one
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
Rear brake disk joy
I have just started the process of changing the rear disks and pads, never done this before, how difficult can it be, well, not entirely straight forward. First of all turning the Electric parking Brake off for maintenance, Having an 2009 facelift edition doesn't help my cause, nothing seems quite as straightforward as it should be. The fuse suggested to be removed to disable the system once turned off varies from fuse 8 to fuse 36, mine is fuse 9, it would have helped if the drawing of the fuse box behind the glove box (it is the right hand support that needs to be released contrary the suggestion in the manual) actually bore some resemblance to the sticker on the inside of the cover. Some searching revealed that is similar to the D4 2010 onwards layout, it has taken a bit of time but I now have the fuse box and numbering of the fuses in an Excel sheet, so tomorrow I can remove fuse number 9 and (hopefully) get on with things.
Just as a question, is there any reason I can't pull the fuse before starting the engine and put the gearbox in neutral so the EPB can't kick into action?
If any one wants the drawings just let me know
Regards
Will
Post #574461 28th Nov 2020 8:23pm
kevinp
Hi Will. It seems to me that the set up and maintenance of the handbrake system is over complicated. I know somebody will chime in and say I did mine wrong. I just left the handbrake off and treated mine like a normal manually operated system to change the shoes. I didn't do all the set that is meant to be done afterwards. I didn't remove any fuses. Perhaps I was lucky but the shoes don't bind and the handbrake works perfectly.
Post #574465 28th Nov 2020 9:10pm
RichM63
France 2006 Range Rover Vogue TDV8 Stornoway Grey
I just put the car into neutral, EPB off, shut it down and disconnected the batt neg terminal. L322 3.6 TDV8 Vogue. 07MY
ML 320 7 Seat full leather etc. (The Black Pearl) Wink
Post #574494 29th Nov 2020 9:03am
DrRob
Tim at Alltrack 4x4 in Malvern if you get stuck... Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
I use www.glenrands.co.uk Great independent specialist!
Post #574496 29th Nov 2020 9:18am
Red Hot one
Thanks for your replies, the thing is that if I put the gearbox in Neutral and turn the engine off the EPB comes on automatically, there seem to be several ways to get the EPB into service mode but they all seem somewhat convoluted and it will be a trial and error event to find which one works on this particular car. My simple mind thought park car, remove fiuse no9, ignition on, box in N ignition off, problem solved. I guess I will have to start thinking complicated solutions to a simple problem. Neutral
Post #574504 29th Nov 2020 10:37am
drakes
I agree with kevinp
Mine is a 3.6 facelift and when I changed mine I just left it in park with the handbrake off same as Kevinp, mine does not automatically apply, I did go through the bedding in process though as I changed the handbrake shoe as well. 2010 3.6TDV8 Stornoway Grey/ Black interior - gone
Post #574526 29th Nov 2020 2:14pm
