![]() | Home > Technical (L405) > Rear door not opening |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000
I replaced both rear Door locks on my TD6 due to this. Not at the same time, they both failed within a few months of each other.
Ah, ok, L405.... need to read more before I reply |
| Gibby Member Since: 05 Aug 2018 Location: Bristol Posts: 29
Check the battery.
| zoso Member Since: 20 Aug 2014 Location: Ayrshire Posts: 79
I had a similar issue with the front passenger door - same symptoms as you have except mine wouldn't open from the inside or outside. Did a lot of searching and eventually found some Land rover site in the US that suggested this is a problem with the soft close doors and can be fixed with ECU update. I checked and although my car didn't have any ECU faults the GAP tool did indicate that an update was available for the passenger front door module. I contacted Patrick at GAP and he sent me an ECU flash for the door module which I applied. Initially that didn't work but I then did the ECU reset (battery terminals) and that cleared the fault. I'm not sure if an ECU reset would have cleared the fault (might be worth trying that first) without the ECU flash but the combination seems to have worked.
