![]() | Home > Technical (L322) > L322 03 td6 brakes locked on |
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 ![]() ![]() |
Following morning went back started up warmed up touched brake pedal normal so into D and drove home normally! Friend in total shock what how when? His parting comments. Fickle these FFRRs like a fit bird,look lovely on the arm but can do much drama. Anyhow I drove her home and she put her lippy and high heels back on! lol.
Doom its back!
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 537 ![]() ![]() |
When I've had an ABS sensor on the blink on a L322, it feels like the brakes are applied and the car wants to stop all on it's own. Can't recall the peddle being hard though?? It can be driven if enough throttle applied.
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
Whenever I lend anything to a “mate” I normally tell them “If you break it you buy it” as they leave the driveway.....😉
Still ongoing and the fault keeps happening, staying local as its my spare FF!
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 ![]() ![]() ![]() |
Maybe take the abs module off and find a place that can test it mate. Not sure what they charge but I remember wheeler dealers doing that and only got charged £250 all be it 10 year ago |
Think I dare say it was the YAW Sensor and despite Gap telling me it doesn't have one! I found one on Ebay and an article suggested a fault in 2003-2004 that causes the above fault. After finding it (rear of centre console bolted to the floor, plug is facing rear floor carpet)
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 ![]() ![]() ![]() |
Connector pins to the ABS module, n/s above the wing.
Brilliant result, never knew that the yaw sensor could do that. Hopefully you've got this cracked ![]() ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
