![]() | Home > Maintenance & Mods (L322) > FBH wizard in Scotland |
| Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 701
Tip top condition battery
| cattona Member Since: 27 Nov 2020 Location: Perthshire Posts: 38
Brand new £400 factory-spec battery eight weeks ago. Tank full. Also, wouldn't a not-tip-top battery prevent the thing from running in the first place, rather than from running hot? 2011 L322 Vogue SE 4.4 TDV8 |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352
MMP in Dundee. "Mikey" on here Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
| tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 190
Hi, have you tried pulling the fuse for the heater ? if it has 3 failed starts it seems to stop working. If you pull the fuse it resets it and then works. Happened to me a few weeks ago when I ran out of fuel and tried to start the car multiple times, removed the fuse and bingo, if its working correctly you should hear a clicking noise from the rear near to the fuel tank. |
| All times are GMT |
