![]() | Home > Maintenance & Mods (L322) > Deployable Side Step weirdness - any thoughts? |
| kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386
Hi All,
| JNC Member Since: 23 Feb 2020 Location: UK Posts: 293
I would try a good ol' reset. Might be best to have them both in the same state when doing so however. |
Battery reset, you mean? Worth a try, I guess.
| Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16403
+1 for a battery reset and go and slap whoever was jet washing around your pride & joy |
Well I've had it on charge all weekend following the battery reset as the battery looked a bit low according to my ctek dongle. It did retract on its own this morning, but it took a lot longer than the driver side before it activated.
| IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 301
As Danwilderspin said give them a good greasing. Mine was sent in to the garage by the previous owner because the steps were not deploying and retracting properly. The garage just gave it a good greasing and that resolved the issue.
I don't think greasing them will have any effect on this issue - they operate fine - its the trigger that seems to be the issue.
| cass Member Since: 12 Oct 2011 Location: northumberland Posts: 797
I wouldn't discount lubrication too quickly, mine was showing intermittent misbehaviour that sounds like yours with no real pattern. I recently managed to break one of the brackets and had to pull one side apart to swap the bits over. I was suprised just how stiff the mechanisms were compared to a new one in spite of regular lubrication. A squirt of lube goes nowhere, it took a lot of time and effort to "free" them off and lube them up and they still are a lot stiffer than the new one.
What is people's preferred method of lubricating these? I've just been spraying everything that looks like it moves or pivots with ptfe lubricant on a regular basis - I've not wanted to use anything more sticky to try to avoid collecting dirt and grit, but I'm beginning to wonder if it's enough.
I reckon the only way to do it properly is to drop them off the car then work some lubrication into the pivots by hand.
| dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291
the mechanism is a poor design and impossible to lubricate whilst on the car and very difficult even when removed.
| All times are GMT |
