Home > Technical (L322) > Normal height only error message
Fatzo
France 2011 Range Rover Vogue TDV8 Ipanema Sand
Heya all!
The other day, driving my 2011 TVD8 4.4, got a message while driving: tire pressure sensor fault, or something like that.
Parked, shut down car then motor on again: no more message.
A couple days later, a message "Normal height only" appeared after i raised the car from subterranean parking. I renders suspension inactive to normal position.
It appeared that i could settle the problem by stopping engine then turning it on again, which cleaned the error. But usually it reappers fast or sometimes...never.....
I dont think its a compressor problem since i raise and lower the car, usually to park it in parking.
I think its a gremlin or a sensor problem.
I'm gonna make a check at the dealer soon.
What do you think the origin of this problem is?
Thanks a lot
Fatzo
Post #575277 6th Dec 2020 7:53pm
scotcruz
Scotland 2010 Range Rover HSE TDV8 Zambezi Silver
Suspect is the sensors.. have you check for any fault codes? Current:
- L560 Velar HSE R-Dynamic D180
- Peugeot 508 2011 - 2.2 HDi GT
Past:
- FFRR V 2010 - 3.6 TDV8
- Citroen C4 1.6i Petrol
- Mitsubishi Shogun 3.2 DID
- Peugeot 607 2.2 HDi
- Nissan Primera 1.8 SVE
- Honda Civic 1.6 VTEC
Post #575321 7th Dec 2020 1:26am
AJGalaxy2012
My L322 gave this message when the compressor was u/s, it seems to get triggered if the compressor runs for a long time to maintain / build up pressure. Try drilling out the filter as described elsewhere on here. BMW i3 Electric Car
2006 VW Touareg 3.0 TDi V6
Post #575322 7th Dec 2020 6:14am
Dolphinboy
+1 compressor
Post #575348 7th Dec 2020 12:20pm
Fatzo
Hey guys, some news
The Range Rover dealer did check the car: the compressor is faulty.
Does any of you get the refs of a genuine compressor?
Dealer is asking 1.100€ to change it
Thx a lot
Fatzo
Post #579522 12th Jan 2021 10:47pm
Rog21
England 2012 Range Rover Vogue TDV8 Buckingham Blue
Compressor is repairable on later cars, there are filter kits and seal kits to replace worn parts usually around £60 just search the internet
Videos on you tube take you through fix
Mine gave the message after standing for a while and I took apart air dryer part and cleaned filters as they were black where holes in metal plates are.
Now no problems but might overhaul mine anyway as we are in lock down and my 322 is SORNed
As far as I was aware drilling filter will help lowering not raising suspension as this is how air is released
Roger L322 4,4 TDV8
Freelander 2 sold
Honda Transalp
Sunbeam S7 deluxe (in bits)
Sunbeam S8 (restoring)
Post #579586 13th Jan 2021 2:29pm
mandelbug
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
I bought a repair kit for mine, went to fit it and found the conrod had snapped and the conrod/piston were in about 6 pieces. Ended up replacing the whole unit. Easily done (4 bolts holding it down, couple of connectors)
Post #579587 13th Jan 2021 2:34pm
