Home > Technical (L322) > Drivers door handle
Ianb4310
Drivers door handle
I went to my RR this morning about 3am to go to work it was -4 outside unlocked the car then pulled the the handle and heard a crunching sound thought this was the door breaking free from the seal as car was white over!!
When I closed the door when I was sat in it the latch did not engage and door bounced back open I did this a couple of times to make sure !!
I then held the door shut and pressed the lock but and it locked but I will not open with the inner or outer handles now!!
Did a search on here seams it could be either the cable snapped or frozen is the only way to tell by removing the door card which is locked shut(I climbed out of the passenger side) ๐Ÿ˜‚
Thanks
Sorry for the long explanation
Post #575329 7th Dec 2020 9:28am
common 'frozen lock' problem..
this can be solved with liberal amounts of WD40 or better still lots of grease packed in the lock..
the door seals will need a rubber lubricant on them like gummi pfledge... ... - .- -.
Post #575331 7th Dec 2020 9:42am
Ianb4310
Thanks I hope itโ€™s just frozen rather than the snapped cable is there a different symptoms for cable snapped
Post #575332 7th Dec 2020 9:56am
Ianb4310
Thanks Stan just got home and door opens and closes normally!!! Phew!!
Wd40 applied to lock mechanism and door rubber
Post #575399 7th Dec 2020 6:56pm
Andy B
I had this a few winters ago in the L322 when all the doors were frozen solid (-10 outside). Ended up climbing in via the tailgate! Thankfully it was dark, so the neighbours didn't see Laughing SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #575402 7th Dec 2020 7:36pm
Danwilderspin
Yes had this on my last ff in my wisdom I got boiling water and the latch was fine but when we got to destination it was ten times as bad Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #575432 8th Dec 2020 12:17am
