![]() | Home > Technical (L322) > Suspension Fault help |
| bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109
Sure you didn't set off in off road height easily done. As well as HDC! Help got CAR OWNER VIRUS! |
| scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391
That I cant tell.. bizzare how the heating pump and suspension code came up together.
Any thoughts on the fault codes folks?
| rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1198
Thoughts on fault code as requested:
Thanks Richard,
| D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 575
When I've had a bad height sensor the output voltage didn't really give anything away. It's supposed to vary depending on the height as it's effectively a variable resistor like a Scalextric controller.
| appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424
Usually get suspension fault if take off too fast, before vehicle has time to raise to normal height. Turning ignition off and restarting again, at a safe and early opportunity, resolves issue. Usually happens 3 or 4 times a year. I'm not losing sleep over it. Previous cars:
| Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601
I would begin by re-charging battery then clearing fault codes and monitor.
| Range Rover L322 Member Since: 03 Sep 2019 Location: South West Posts: 342
All the above are good points, however it is worth noting the first few times it gets frosty each year there are a significant number of instances of L322 suspension drops.
Thanks folks, its been 2 days and it has been fine.. so could only think of the gremlins from the recent rain, then snow and the frost.
