Home > Technical (L322) > Replace ignition key shell and battery
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
Hi Everyone,
I just went through the ordeal of replacing the key shell and battery for the key to my 2009 L322.
After wasting time on a couple of shells that looked like the right one, but were not, I finally got the right shell and battery!
The only thing to remember is that the old key is glued shut which I assume means it’s waterproof (is it really?). The new shell just snaps together.
I bought the shell from here.
https://fasterautokeys.com/collections/lan...-2005-2010
They offer two different styles of key blade. You can e-mail them a photograph of your key to make sure you get the right one! I thought I ordered the right one but since I was keeping my key blade, I actually needed the other one. In the e-mail you should specify if you will have the new blade cut at a local locksmith or if you’ll swap your original blade for the blank that comes with it.
They were really helpful and shipped quickly!
I also bought a new battery off of eBay. Don’t forget that it’s soldered to the circuit board! So, don’t try prying it out!
Here’s a good video that shows how to replace the battery once you have your key disassembled (VL2330).
And here’s a good video (made by the same people who sold me the shell) showing how to open your original key and swap the blade and circuit board.
Good luck!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #575437 8th Dec 2020 1:19am
