Home > In Car Electronics (L322) > Clarion CD Changer Intermittent Fault
Parallel
Looking for some tech help with a faulty Clarion CD changer please. Car is an 07 3.6 TDV8 L322.
Having trawled through posts via the search function and other googling, i'm still struggling to find any info on a fault the same as mine.
I have the frozen touchscreen, with LR logo and flashing amber light on power button.
Have traced the fault via the fiber optic loop on the MOST system to be in the Clarion CD changer in the glove box.
Here's the strange bit; if I unplug the unit and then connect it again, the system works fine without fault - until next time the car is used or the module has shut down. No disc read errors etc, and no codes in GAP tool.
I am aware there is a guy on ebay who does the refurbished units but would like to see if anyone has experienced the same issue as me here first. When working, it reads discs and plays just fine.
Have taken the unit apart and done a visual check with an eyeglass on the PCBs etc. for anything obvious, but as it works when power cycled/reconnected every time I cant help but think that it's not necessarily a hard fault.
Also, have tried the battery disconnect/reconnect procedures and shorting the leads when disconnected to reset modules.
Always prefer to learn what the fault is and repair myself where possible.
Any help/pointers greatly appreciated! Thanks
Post #575563 9th Dec 2020 2:19pm
fibre optic uses light so maybe dirt in the connections? ... - .- -.
Post #575673 10th Dec 2020 4:46pm
Sonearly
United Kingdom 2017 Range Rover Autobiography SDV8 Santorini Black
Found a link that might help. It is from our friends across the pond
Go to rangerovers.net and search
Touch screen Frozen Locked knob light flashing orange...fix
Lots about it on there.
Post #575901 12th Dec 2020 10:45pm
thats in our wiki as well.... ... - .- -.
Post #575917 13th Dec 2020 9:45am
Parallel
Thanks for the replies both.
Stan - I did clean the connectors to rule this out but they were not at all dirty anyway.
Sonearly - I have seen the rangerovers.net posts thanks, however this is not what I am asking. My fault is specifically with the CD changer and i'd like to fix it instead of just bypassing the unit.
Post #576232 15th Dec 2020 11:42am
theres a contact number for a chap who repairs these cd changers in this thread,
https://www.fullfatrr.com/forum/topic57477.html ... - .- -.
Post #576236 15th Dec 2020 11:53am
