![]() | Home > Technical (L322) > Car wont start....HELP |
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 508 ![]() ![]() ![]() |
Ah ok |
Ashmyster79 Member Since: 07 Nov 2020 Location: Essex Posts: 247 ![]() ![]() ![]() |
ANDDDDDD........she wont start!!!!! Next day after have the exhaust system changed I go to do a Tesco run and battery dead again!!!
4434Morrison Member Since: 02 Mar 2020 Location: Folkestone Posts: 185 ![]() ![]() ![]() |
Go for the Varta G14 AGM battery, I know its German, but hey - quality over price... 2012 4.4 TDV8 Vogue SE Current
On Tanya now....
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 700 ![]() ![]() ![]() |
Try & get one with the longest warranty perhaps?
I have read up and it could point to a drain and not a battery. I see 3-4 drain issues but will start with the battery. I will charge it again today and leave it off over night then try it again see if it has life in it or not then assess. Cheers for the tips. In a weird way I hope it is a duff battery easier to replace perhaps. Current Cars
This is the one I got fitted 4 years ago. I top it up once a week with my Ctek charger as car only only gets used a couple of days a week for short journeys. Though its what you feel comfortable with. There are so many variants out there to choose from. Good luck
Cheers Strider. Sounds like I do the same as you in relation to short journeys. Once or twice a year its 100 miles+ but mainly its 5 mins here orschool run there.
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
An 020 battery will fit nice and snugly into vehicles of your vintage. Gives a little more comfort factor. Doesn't negate the need to use trickle charger every now and then though! Previous cars:
What does the 19/20 mean in relation to the battery. Always good to knowledge up 😄 Current Cars
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 351 ![]() ![]() ![]() |
019/020 refers to the dimensions of the battery.
Ah great. Thanks for the info Current Cars
