Home > Maintenance & Mods (L405) > L405 brake wear sensors.
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Hi , Just wanting to know is there a brake wear sensor for each brake pad set ?
IE, Two sensors for rear pads , L/H R/H.
Two sensors for Front pads, L/h R/H.
I have received my new Cross drilled , slotted, discs and new pads from supplier , but one only one of each sensor front and rear.
Any advise would be great Thank you.
Post #576053 14th Dec 2020 7:45am
Jayk69
If anything like the L322 you will need one for each axle.
so one wear indicator for the front and one for the rear.
if your pads are not worn you may even be able to use the existing ones. I did mine recently and lust unplugged it and plugged it in again. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #576067 14th Dec 2020 10:04am
Yep, only one front and one rear. Thumbs Up if you can get the sensor off intact you can reuse, the rears are a bit fiddly to get the connector on. Best will in the world I broke mine when I did my pads. There is nothing that can't be fixed with a hammer😜😜
Post #576176 14th Dec 2020 9:54pm
jettec
Thank you for the info .
I thought they may have stuffed up.
Post #576192 15th Dec 2020 12:01am
