![]() | Home > Technical (L322) > Webasto auxiliary heater playing up |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 ![]() ![]() ![]() |
From the workshop manaul:
cattona Member Since: 27 Nov 2020 Location: Perthshire Posts: 38 ![]() ![]() ![]() |
Sorry I did not specify. I had a brand new OEM correct battery installed when I bought it specifically for that reason. Yes, fuel is 3/4 full or full. 2011 L322 Vogue SE 4.4 TDV8 |
That's good, so one area should be OK. How about the rest? Cheers
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
My understanding (for the late facelift models anyway) is that it auto detects whether to heat or vent depending on ambient temperature. You can't set it via the remote. 2010 4.4 TDV8 Vogue SE |
Jack last Member Since: 29 Aug 2020 Location: Scotland Posts: 50 ![]() ![]() ![]() |
Sounds like it needs reactivated if it’s greyed out on the touchscreen menu?
Jack
Fair enough worth reactivating with the iid tool as the fuse was removed so might work |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
I am in the same boat.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 998 ![]() ![]() |
Activate the fbh with the remote at the same time blast the fbh air intake with air I use my line off my compressorit mite help it fire up and burn off any crap inside. It worked wonders on our D3 |
I'm going to check the coolant pump is working properly.
Well, no, I do not have an iiD tool nor has this been done. It has been at Strathearn Engineering who are LR specialists who said "it's working" and that they "got it to switch on" and that they "got it warm". But it is never warm. Here are the symptoms:
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4340 ![]() ![]() ![]() |
Try this: Turn both temp dials up to max heat the night before. Next day, press the remote as usual and after 15mins go and see if that's made a difference.
I will do that. And I'd be interested what it does. HOWEVER, before that wasn't necessary AND it wouldn't explain where the choice between heat and vent, that was "tippable" on the TSD, where that has gone. 2011 L322 Vogue SE 4.4 TDV8 |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 830 ![]() ![]() |
The MY11 was an FBH victim of JLR being too clever for their own good.
