![]() | Home > Technical (L322) > iid tool to turn towing on |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35838 ![]() ![]() |
its under BCM-body control menu... ... - .- -.
Landmark Member Since: 22 Nov 2020 Location: Hampshire Posts: 118 ![]() ![]() ![]() |
Hi Stan thanks for your promt reply, found it. i wasn't to sure which bits to turn on so turned on individually. Tow ball yes tow stability yes and tow 13pin fitted. On uploading it went through its functions and then said upload failed, i then hit continue and it said 100% complete. I went back in and all are activated. Also had persistant fault code b1311-96 (2f) any ideas??? sais clock module component failure-internal fail. Is is it refering to actual clock ie time because no problems. |
Rodjules Member Since: 03 Mar 2016 Location: Bishops Stortford Posts: 68 ![]() ![]() ![]() |
I have that exact same clock fault message on my 2012 Westie and it won't clear with the GAP tool. On the positive although
