![]() | Home > Maintenance & Mods (L322) > Water Ingress |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
Possibly leaking sunroof drains or antenna.
Ricardo Villa Member Since: 01 Nov 2020 Location: Worcester Posts: 186 ![]() ![]() ![]() |
Thanks, going to check drains properly but initial look they seem clear and no dampness around the sunroof. Will look at antenna and maybe run some sealant around it as a precaution. No signs of water ingress on headlining. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4342 ![]() ![]() ![]() |
Top tailgate hinges I've read too Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
He probably had a blocked drain which was fixed. And as always with LR they recommend you replace every last thing they touch to get to the broken bit...... so if the headlining was a bit damp then new headlining would be specced. Even if it was salvageable. If there is no sign of damp then I wouldn’t be overly concerned.. It sounds like the previous owner had the water shedder fitted. If you can get a look down into the cavity behind the electronics then you will get an idea whether there is any water trapped in the wheel arch seam. There is nothing that can't be fixed with a hammer😜😜
Cheers guys, few things to look at. I was baffled at the replace roof section option, as it wasn't done the Headlining has no marks whatsoever so can't see any reason. I will dig out the invoice the dealer had commented on and will see exactly what they said. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
