Home > Technical (L322) > Draper egr activator / tester.
Daniel0103
United Kingdom 2008 Range Rover Vogue SE TDV8 Stornoway Grey
Hello, do you know where I would get the information to connect to a Draper EGR Activator to a Range Rover, L322 3.6 2008, it appears to be exactly what I need but not about the connections?
Has anyone used of these?
Would it connect to the grey plug under the engine cover, if so how?
Thanks, Daniel
Post #577414 27th Dec 2020 8:06pm
Pawl
If you Google the instruction manual you'll find a copy.
It looks as though you disconnect the grey multiplug to the EGR to make the connection to the Tester.
From the brief view of the instrcutions I saw, it appeared there wasn't a compatible connector with the tester, so you'd end up having to improvise some connections.
You can't really clean the EGR valve components without removing them, so quite a lot of work.
From what I've personally experienced and seen elsewhere, most of the EGR failures are actually electrical rather than sticking valves.
If you've got fault codes / failure symptoms, it might be worth getting a secondahand replacement valve ready to put in to get rid of the fault codes and a blanking kit to remove any risks of EGR mechanical failure causing engine / turbo damage in future. Paul,
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Post #577419 27th Dec 2020 8:46pm
Daniel0103
Hello,
Thanks for the reply. I too looked at the instructions and not sure of the connections.
Post #577422 27th Dec 2020 8:54pm
Pawl
I had to do some work on our TDv8s EGRs a couple of months ago & replace 1.
The Draper connectors shown in the manual don't match those on the EGRs. Paul,
Post #577424 27th Dec 2020 9:10pm
